Results 1 to 8 of 8
    ohio
    Default WTB: Van Diemen FC bolt kit suspension
    I'm looking for the AN style bolt kit to fleshing up the suspension.
    Washers, nuts bolts.
    Does anyone have this as a complete kit?
    Liked: 803
    With all the small variations year to year, not sure such a ‘kit’ exists.
    If you’re going to be your own mechanic, a great way to learn about the car would be to measure up everything you need. We’re only talking about 30 or so bolts. :-)
    multiple sources of AN hardware are available online.
    Mokena IL.
    Liked: 59
    Save yourself a lot of time and aggravation with these handy gauge's
    https://www.pegasusautoracing.com/pr...sp?RecID=10835
    https://www.pegasusautoracing.com/pr...sp?RecID=29562
    Senior Member rockbeau25's Avatar
    Fitchburg, WI
    Liked: 167
    What Thomas said. I just went through the same thing converting my VD to wide track. Measure every bolt and order accordingly from Pegasus.
    Van Diemen RF99 FC
    Liked: 1486
    That gauge is $10.50 from Aircraft Spruce.
    I've found this hy-loc rivit gauge to be a complement to the drop-in gauge, because it measures grip length. That tells you what bolt size to order even if a bolt that was too long or too short was used previously. https://www.ebay.com/itm/324708951482 A bolt with that grip will then be properly sized for two AN 960 washers and a jetnut.
    When you order from Spruce pay attention wo which warehouse its shipping from - they have one in Atlanta and another in LA.
    ohio
    Thanks everyone this really helps!
    it's a 2000 model car if someone has already done the digging.
    I will track / post it here to save someone else the efforts.
    Liked: 1486
    Primus probably has a bolt map for this car
    Liked: 1262
