Page 2 of 2 FirstFirst 12
Results 41 to 44 of 44
  1. #41
    Senior Member Spengo's Avatar
    Vancouver, WA
    Liked: 123
    Quote Originally Posted by redcar9 View Post
    Does this look like a good center point to balance gearbox / oil box?
    Heh, I split my car 6 times last year working on my clutch slave cylinder/throwout bearing and debugging transmission issues. First time took me all day and a helper and I used every ratchet strap I could find to hold it up. By the last time I could have it apart and back together by myself in under 45 minutes and I just used two straps. The transaxle is not actually very heavy but it's helpful to have two so you can adjust the angle.
    Found a pic of how I had it with two straps
  3. #42
    ohio
    Quote Originally Posted by Spengo View Post
    Thanks! This totally was easier than expected.
  5. #43
    Senior Member ejsprint30's Avatar
    Ohio
    Liked: 79
    I just lost my starter at my last track day. It was a 10 pinion and 135 ring gear. Prior to starter going, it would periodically have issues engaging. When I put a new 10 pinion on, it absolutely would not engage...seems to work fine with a 9. My car did come with a spare starter that had a 9 on it.
    Should I figure out how to make the 10 work...or stick with the 9?
    EJ Korecky
    check out my products on Facebook
    https://www.facebook.com/profile.php?id=100075564523814
  6. #44
    Ohio
    Liked: 79
    An update...I swapped the flange mount from the dead 10 tooth starter and put it on my spare. I put the 10 tooth pinion on it and it engages perfectly now...must have been a slight difference in the flanges.
    EJ Korecky
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. rg2
