Results 1 to 6 of 6
Thread: Pilot bushing
    eaton co
    Liked: 12
    Default Pilot bushing
    Does anyone have a part number for the Pilot bushing for a Formula Ford? probably brass
    Thanks in advance.
    Allen
    New Mexico USA
    Liked: 58
    Default Pilot bearing
    Quote Originally Posted by Speedy_Farmer View Post
    Thanks in advance.
    Allen
    Here is the Pegasus Racing URL for the part (it is a needle bearing, not bronze!) --
    https://www.pegasusautoracing.com/pr...asp?RecID=3478
    Derbyshire, United Kingdom
    Liked: 322
    INA # is F331262
    OD 21mm
    ID 15mm (nominal, actual 15.07mm)
    Depth 15mm
    eaton co
    Liked: 12
    thanks, I was hoping for a brass one I need it a little longer
    Liked: 322
    Hmm...why would you need a longer, brass one?
    HK1518RS is a roller bearing, same OD/ID but 18mm deep.
    New Mexico USA
    Liked: 58
    Default Pegasus bearing dim.s
    I just measured a brand new Pegasus one ==> 21 mm OD x 16 mm Long (nominal dimensions).
    I also wonder what the benefit of a brass (bronze?) one would be? If some dimension might need to be machined to fit, you might consider starting from oil-embedded sleeve bearings. All kinds shown @:
    https://www.mcmaster.com/products/bu...ain-bearings~/
    Lee
