Results 1 to 5 of 5
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Default Wanted-Lower Rear Wing Element for Van D
    Snapped an end plate bolt of in mine.
    Liked: 3317
    Quote Originally Posted by Bob Coury View Post
    Is it not repairable? I would think it would be. If not, why not?
    Liked: 1488
    but nut over snapped bolt
    fill nut with MIG weld
    remove
    Liked: 1262
    Or dremel a small slot in it and use a screw driver.
    The point is it should be removable.
    Jupiter, Florida
    Liked: 79
    Thanks all.
    I think that there was dissimilar metals involved, hence the reason the head snapped. Screw slot would have been difficult to make as it would have had to be below the surface of the rib. And I did not want to apply heat as the rib appeared to be composite with a bonded nut.
    I ended up using a carbide bit on a Dremel to make a started hole, step drill, then re-tap.
