Results 1 to 5 of 5
Thread: Pan Bonding Qty
    Destin FL
    Liked: 645
    Default Pan Bonding Qty
    Gents:
    I am going to bond my RF-95 pan next week with Hysol 29354 E-120HP Epoxy. As not to over purchase, how many tubes should I buy?
    V/r
    Iverson
    San Jose, CA
    Liked: 25
    I went through most of 2 duo-pak's on my ADF recently.
    *Having the correct duo-pak "gun" and mixing tips is critical (unless you want to hand-mix because you can't wait...).
    ADF MkII #11
    Liked: 1262
    mixing tips and guns at the bottom of the page:
    https://www.mcmaster.com/products/lo...umber~e-120hp/
    I would not try mixing any other way.
    I used all the 1.6oz stuff.
    Liked: 707
    I used six of the 1.69oz cartridges on my RF95 belly pan.
    Connecticut
    Liked: 157
    Default Mixing in a ziplock bag also works in a pinch
    Putting the two parts into a ziplock and then getting the air out of the bag before sealing works as well. Then you can knead the bag for a while and get a good blend. Once mixed, get the bag on a flat surface, move the epoxy away from one corner and snip off the corner. You can apply like icing a cake, or better, work the material into a syringe and have that on hand to do the application. Maybe gorilla tape up the entrance of the bag once you have it sealed so you don't get a problem. Or just pay attention to not allowing an unzipping event.
    This also works for mixing small batches. Probably why you can buy the bags in tiny sizes
