    Senior Member John Green's Avatar
    Milwaukee Wi
    Liked: 104
    Default Pinto piston rings
    I am replacing the rings on my Pinto 2.0
    I have honed the block and have what I think are either JE or CP pistons.
    They are marked .005 over.
    Any help on what and where to get?
    Liked: 1488
    Those are CPs I believe, being Ivey's. I'd give him a call, the pistons I bought from him came with rings.
    The J&Es are more tricky. They use thin "normal" top rings, but the oil control rings are the original ford metric so you have to buy two sets to make one. That's for the J&Es with the SCCA logo.
    There are regular J&Es that use a standard ring pack and are otherwise identical to the SCCA ones.
    Try Total Seal. They can make most any rings if you can tell them things like bore, ring groove thickness and depth to the bottom og the groove
