Results 1 to 9 of 9
    San Jose Ca
    Liked: 80
    Default I'm looking for this type of washer?
    Hello All, I saw these washers? at the last event I went to can anyone point me how to get these or what there called?
    Thank you
    Memphis, TN, USA
    Liked: 416
    Quote Originally Posted by CM/FFdriver View Post
    Thank you
    It might be a step-down bushing for a shock mount. Depends on the size.
    Charlie Warner
    fatto gatto racing
    Ft. Myers, Florida
    Liked: 225
    Default Top hat bushing
    If all else fails, try McMaster-Carr. They carry a range that looks like it will suit.
    Derbyshire, United Kingdom
    Liked: 322
    Looks like a misalignment bush for a rod end or spherical bearing. What size is it?
    Auburn, Georgia
    Liked: 44
    If you can PM me the dimensions I can see if we have anything similar. Since acquiring the NP01 program from Elan we inherited many old Van Diemen parts and part numbers that we still use on our cars. The oldest VD part number dates from 1984 and was a top hat bush like yours, although we have since re-drawn the part and given it an NP01 part number!
  10. #6
    Senior Member Spengo's Avatar
    Vancouver, WA
    Liked: 123
    I called them top hat bushings too. Brad knew what I meant. These are the sizes used on my car.
    https://www.primusracingparts.com/Sw...16-_p_368.html
    https://www.primusracingparts.com/Sp...14_p_1539.html
  11. #7
    Vancouver, BC, Canada
    Liked: 231
    Ben, is that actually a bushing that goes inside the rod end, or is that washer at the end of a single shear setup like a balljoint (it looks like the latter to me).
    If that's the case, you can use something like this:
    https://www.pegasusautoracing.com/pr...p?Product=3068
    -Mark
    Mark Uhlmann
    Vancouver, Canada
    '12 Stohr WF1
  12. #8
    Liked: 1262
    I've bought these and adjusted them for ones I couldn't find elsewhere
    "Sleeve washer"
    https://www.mcmaster.com/products/wa...erial~steel-1/
  13. #9
    Roseville, CA
    Liked: 46
    Default Fast Forward
    https://www.fastforwardracingcomponents.com/
    They usually have them in stock, give them a call or send them a message. They have loads of different sizes.
