Results 1 to 13 of 13
    Senior Member SV@RHC's Avatar
    Livermore, California
    Liked: 63
    Default Ralt RT5 Starter
    I don't know how old this starter is, but the pinion gear is very worn and grinding with the ring gear. I think it's some type of Bosch unit. the only numbers i see on the casing is D 001 101 345. Does anybody in the great APEX brain trust know the make and model??? I would sure like to get a couple.
    Sacramento, California
    I’ve been on the same quest for my Anson. As best as I’ve found is they were from a big BMW motorcycle from the era. I still have the original unit that works on the bench. I’d really like to find something better. A company called IMI does some nice stuff based off a gear reduction starter. Yours appears to be a good looking rebuilt original type rebuild. Does the label say who did it?
    Liked: 909
    Can you find a new pinion gear??
    Liked: 855
    I think you want to find the "right" pinion gear! If this was rebuilt 2 years ago as the sticker says, there's no way the gear should be hammered this quickly. Think of how many more times your street car was started in the last month!
    Liked: 63
    Default pinion
    Thats still an option, I'll look into my local starter guy and hopefully he can come up with something. i know the first question will be "whats it out of."
    Liked: 947
    Scott,
    Look up Marc Bushman here on Apex. He can help you and can work his magic to make it perfect and reliable.
    Dan
    Liked: 63
    Scott,
    Dan
    Hey Dan,
    I've already spoke to mark. Great guy. the starter functions perfectly electronically. The issue is the pinion gear, without knowing what the model/manufacture is finding the correct pinion is difficult at best. not sure what to short of machining a new one.
    near Athens, GA
    Liked: 830
    Quote Originally Posted by SV@RHC View Post
    Hey Dan,
    I know nothing about these cars or the starters... but .. can't you just count the flywheel teeth and get a pinion that fits that? It might take a bit more mod to get it on the armature shaft but ... it's a start (no pun intended)?
    Liked: 141
    Default Number
    Could your D in the part number be a zero? Lots of Bosch starters start with 0-001-XXX-XXX. Needs to be 10 numbers. Did you call the phone number on the sticker?
    Liked: 63
    Default Starter and or pinion
    Thanks, this search has become very educational. When I use the ten-digit version of the number I get a Bosch starter from an 87-88 BMW. It looks very similar. but I'm now looking for a cut sheet with dimensions and orientation to be sure.
    I am not opposed to switching over to a Tilton or Denso. Just need the appropriate 9 tooth model and a source for the adapter ring or at least a drawing of.
    Hi Torque IMI Performance Products,Inc.
    If I have issues with mine I plan to send it to these guys along with the adapter plate. They can do one off stuff with a strong gear reduction motor that should turn over any supervee. For all I know they may already have something ready made.
    Derbyshire, United Kingdom
    Liked: 322
    CHV Engineering list a starter motor for the RT5 Super Vee:
    https://chv-engineering.com/products/starter-motor-vw
    Liked: 63
    Default Ralt Parts
    Thank you, what a find for Ralt parts in general.
    SV
