Results 1 to 6 of 6
    Houston, TX
    Liked: 75
    Default Titan Series 1 pressure rotor set
    I am rebuilding the Titan dry sump pump that pressurizes my 2.0 L Pinto engine in my '88 Reynard FC. It is a Titan Series 1 unit and I need a pressure/rotor gear set. Pegasus lists the gear set for the Titan Series 2; however, not the series 1.
    Anyone know of a source or have a set available?
    John @ 713.553.5475
    Derbyshire, United Kingdom
    Liked: 322
    Maybe worth contacting Titan directly? Their email is: sales@titan.uk.net
    Houston, TX
    Liked: 75
    Thank you for their e-mail address. I sent an inquiry. If anyone stateside has parts, I would welcome a conversation
    Houston, TX
    Liked: 75
    I received the following reply from Titan explaining the part is no longer supported. If anyone has a used pump that I can scavenge for parts, please let me know.
    "Good morning John,
    Unfortunately with this being discounted approximately 25 years ago, we don’t carry stock of the rotors, bodies, shaft etc.
    There are some common parts between this pump and our series 2 so we can offer some spares, but this refers to the PRV assembly and seals.
    Kind regards
    Brian Love?
    Account Manager
    ?As of 1st October 2022 our opening hours will be changing to:
    ?Monday ? Thursday: 0800hrs ? 1700hrs
    ?Friday: 0800hrs ? 1400hrs
    ?Titan
    ?Harley Industrial Park
    Paxton Hill
    St.Neots
    Cambridgeshire
    PE19 6TA
    Main: 01480 474402
    Mobile: 07881349942
    Direct Dial: 01480 702194
    Email: brian.love@titan.uk.net
    Web: www.titan.uk.net
    [IMG]file:///C:/Users/nbkt3cu/AppData/Local/Temp/msohtmlclip1/01/clip_image004.gif[/IMG]
    [IMG]file:///C:/Users/nbkt3cu/AppData/Local/Temp/msohtmlclip1/01/clip_image006.gif[/IMG]"
    [IMG]file:///C:/Users/nbkt3cu/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg[/IMG]
    Liked: 322
    Sorry they weren't able to supply the parts you need.
    Am I right that the Series 1 has 3 clamp bolts, not 4 that is more usual now?
    Quote Originally Posted by jtaphorn View Post
    If it were me, I'd probably look into a more modern part to upgrade to. If it has to be that part, I might have something among the many totes of parts I recently acquired or in a box of several pumps I bought several years ago. But since I'm not an engine expert, I'd need pictures/details to be more helpful.
