    Destin FL
    Liked: 646
    Default RF-95 Water Neck Spacer
    Gents;
    From the engine block the the front engine x-plate mount. No damage. Any help?
    V/r
    Liked: 1487
    I'll make a better suggestion:
    motor mounts that attach to the block and go to a vertical vibration mount attached to the frame where the current mounts go.
    The existing mount doesn't take into account the different deck heights, gasket thicknesses, shaved heads, etc. And, the 2-3 bolts holding it to the head are not only critical, but damn hard to check.
    moving the mounts to the block solves a number of ills, but requires you to model the bell, block, rear frame, and front frame mounts.
    Senior Member lil_fatboy's Avatar
    New York
    Default Spacer
    Rick,
    I have it if you still need. Haven’t been on in a while.
