Results 1 to 5 of 5
Thread: AIM problem
    San Francisco
    Liked: 77
    Default AIM problem
    So I did a 360 degree spin the other day and noticed that the water temp numbers was no longer there and “sat 9” was in the same spot.
    No longer getting any RPM readout or on Smarty either. Not sure if the spin caused anything or was a coincidence.
    racing next week and have Solo on steering wheel but I don’t like not having water temp.
    car is a DB6 Honda. EVO4 I believe is the sys I have.
    Hybels
    near Athens, GA
    Liked: 842
    Would suggest that you re-upload the last channel configuration that you were using (you DO have a back up of that, right ?? ). Looks like something got messed up and you're seeing part of the setup for the GPS, that I assume you also are using. Just a guess since my old AIM doesn't have GPS.
    If you don't have a copy of the configuration, suggest you DOWNLOAD what's there and see if it makes sense and go from there.
    Liked: 952
    Richard,
    If you lost RPM and water temp, it might have something to do with your CAN connection from the AIM to the ECU. Suggest disconnecting and reconnecting the plugs to the dash, then connectors back to the ECU.
    Regards,
    Dan
    Los Angeles, CA
    Liked: 290
    Contact AIM USA Tech. They are easy to reach and VERY good at resolving most problems.
    San Francisco
    Liked: 77
    Default Found it!
    Thanks guys. On a second inspection connection to ECU had come loose.
    Hybels
  9. The following 5 users liked this post:
