Results 1 to 11 of 11
    Sydney, Australia
    Liked: 146
    Default Hawke - broken rear drive shaft.
    I broke a drive shaft on my 50 year old Hawke Formula Ford today. What would be a specification of steel that should be used in a new shaft?
    Senior Member Raleigh's Avatar
    Sydney, Australia
    Default Hardi Spicer
    Give Hardi spicer in Moorebank a call Monday, they will sort you out. They have upgraded, straightened and balanced many drive shafts for me over the years.I would lose the Chrome.
    https://www.hardyspicer.com.au/?gcli...SAAEgIkU_D_BwE
    Liked: 3308
    Quote Originally Posted by Raleigh View Post
    ...I would lose the Chrome....
    Good comment - chroming can make steel brittle and reduce its fatigue resistance.
    Liked: 1488
    any time you electroplate a stressed race car part it should go through a hydrogen bake-out. If you specify mil-spec plating it's part of the process.
    Sydney, Australia
    Liked: 146
    It’s not going to be plated this time. In this part of the world, nearly all platers have gone, and those who are left aren’t interested in one off jobs.
    London
    Liked: 40
    CDS (Cold Drawn Steel) is what you need. Hawke had a different way with the donut tripod thingy where they bored out the flange for the tube. Lotus etc machined down a stub to insert inside the driveshaft. They done the same on the Elan half shafts.
    https://www.instagram.com/p/BujkB4tFQxc/
    That's how I've made mine in the past.
    Sydney, Australia
    Liked: 146
    Sadly, Hardi Spicer could not supply the three pronged end. Said they were no longer available. However, a nice man at Bankstown has them on the shelf, and will make them next week.
    Sydney, Australia
    Liked: 146
    Quote Originally Posted by kevskisps View Post
    Thanks for that. I have found someone to make them for me. I could do it myself, but I'm running out of time.
    London
    Liked: 40
    2nd hand Lotus Elan half shafts are a good source for these. Loads about when owners convert their Elans to CV joints
    Sydney, Australia
    Driveline Services Brunker. Road?
    QUOTE=Hawke;651441]Sadly, Hardi Spicer could not supply the three pronged end. Said they were no longer available. However, a nice man at Bankstown has them on the shelf, and will make them next week.[/QUOTE]
  14. #11
    Mississauga, Ontario
    Liked: 902
    You can nickel plate this with no ill-effects, if you are after a clean and shiny look. You'll need to autosol them once in a while...
    cheers,
    bt
