Results 1 to 2 of 2
    South Florida
    For Sale Febur race radiator/cooler for any fluids application
    Have a couple new old stock Febur coolers sitting around not getting any use so figured i'd offer them up here should someone be able to put one to use. If you are not aware Febur coolers is a company out of Italy that has built a reputation over the decades as the finest manufacture of liquid coolers(radiators) in the world.
    What i have to offer are 2 different sizes of radiators. They are actually oil coolers but can be used to cool any liquid actually. What makes them specifically oil coolers is the internal structure of the core. Regular water radiators have a simple and empty pass through core channel where as a good quality oil cooler will have a substrate inside the core channels that looks something similar to the 'cooling fins' seen on the outside of a radiator. The "fins" on the inside draw out much more heat from the fluid passing through it and pass that heat on to the core walls where the cooling fins on the outside do their work shedding heat with the help from passing ambient air.
    However, while these work amazing as oil coolers they can actually perform better in all instances than any regular radiator. Need to add some engine coolant capacity and more optimal cooling abilities without adding too much weight, or have very limited space, then these might be an option to consider. Basically any fluid you can think of that needs highly efficient cooling capacity this would be something to consider using.
    Now these particular coolers were set up for racing motorcycles therefore they are already set up to be mounted around a regular motorcycle radiator. However, they can actually be used anywhere you wish to put them. Just make sure you get air across the fins and they work great. So great in fact these coolers have kept highly strung race engines running all day in 100+ outside air temps with no issues. Not sure if any of the following matters but may give someone a reference point. The rad for 600cc engines adds 1/2 to 3/4 liter oil capacity and was run on engines putting down 140+ to the wheel. The slightly larger rad for the 1000cc engines adds 3/4 to 1 1/4 liter oil capacity and was use with engines putting down 200+whp.
    Don't forget these can be used to cool any fluid, so not just stuck with cooling oil.
    As mentioned Febur is the premier producer of coolers around the world. When purchased each rad cost $800. Of course not looking for that(wouldn't we all like to see every dime we spend on our racing come back to us), but feel a reasonable price for a NEW never used part of this quality is easily worth $250 to a discerning buyer. You have 2 size options to choose from which will be listed below.
    Also seen on the pics will be adapter plates made specifically for the 600cc/1000cc Honda motors. Both use 8an fittings. If one wishes to purchase either adapter will sell for $250 per unit. If you buy this adapter you can purchase any rad you want to fit your application. If you want both the radiator and adapter let me know and well put a discount deal together.
    Let's call one the 600. Adds 1/2 to 3/4 liter capacity and can run/cool any fluid you wish, and do it better than any regular open core rad. Fittings are 8an. Overall size is length(11.5inch end tank to end tank or 14inch tab to tab), height(core 3inch or core plus mounting tab 3.5inch), thickness(1.25inch core)
    The other let's call it the 1000. It adds 3/4 to 1 1/4 liter capacity and can run/cool any fluid you wish, and do it better than any regular open core rad. Fittings are 8an. Overall size is length(12 inch end tank to end tank or 14inch tab to tab), height(core 4inch or core plus mounting tab 5inch), thickness(just under 1.5inch)
    Destin FL
    Liked: 648
    If nothing else, these are drop dead gorgeous. GLWS.
    V/r
