    Gambier, Ohio
    Default AIM MXL Slave5 Config Err
    I get this when the GPS is plugged in. Any ideas on how to make it go away?
    Paso Robles, CA
    Liked: 286
    Change your configuration, you probably have a channel expansion, LCU-One Lambda or other Aim expansion device configured. The message is just indicating that it doesn't see the configured device.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Gambier, Ohio
    Default Solution.
    The solution was to upgrade the firmware. Thanks, David Ferguson, for all your help!
