    Senior Member cliff's Avatar
    kansas city, MO
    Liked: 72
    Default Oil pump pipe thread
    Looking for the thread count on the Honda oil pump. Pushing oil out…outside is typically -10 or -12 going to the oil tank. What is the thread going into the pump housing…metric..? I don’t have much experience with these fittings or how to measure them.
    ‘please and thanks.
    Derbyshire, United Kingdom
    Liked: 322
    I would think they will all be AN dash fittings. If so, female threads have a female cone (the female cone on BSP goes with the male thread). Metric and AN have very different cone angles.
    Ideally check with a TPI gauge but, if you don't have access to one, try carefully test-fitting a known connection into the port.
    Liked: 4359
    Cliff,
    It is not a pipe thread. it is "straight-cut' and requires a sealing 0-ring. If yours is leaking, either the fitting is cracked (unlikely), the sealing 0-ring is damaged, or it is the hose/hose fitting. I would expect the 0-ring.
    Cliff and I communicated directly. It appears 12 AN male to 12 AN o-ring is what he needs.
    kansas city, MO
    Liked: 72
    Greg is 100% correct. Thank you!
