Results 1 to 10 of 10
    Innisfil, Ontario, Canada
    Liked: 229
    Default Reynard 87F Brake Rotors needed
    Looking for a full set of LD19 brake rotors for a 87 Reynard F1600 car. Also have interest in an exhaust system. Any parts that you have that are surplus specific to this era (87-92) would be of interest. brian.bgr@xplornet.com
    Brian.
    Liked: 1878
    If you can't find any, I can make them for you. However, to be safe, we would need to verify the dimensions - I've seen all sorts of different layout rotors on those Reynards!
    Liked: 229
    Thanks Richard, it may come to that......hoping that the Reynard brotherhood may be able to help LOL. Will reach out when it becomes a thing.
    Paddock Lake WI
    Liked: 193
    Have you reached out to TDI directly? Or alternatively Pegasus carries their rotors.
    Paddock Lake WI
    Liked: 193
    I'm also sure Averill has a source.
    Ontario Canada
    Liked: 160
    Brian,
    From memory 90 series VanDiemen are the same. If you don't have one, let me know I have lots you can try.
    David
    Liked: 229
    Averill doesn't have a supply currently, Pegasus list only for Reynards up to 86, The VD ones would work however the wheel hats are 5/16 threaded and the VD is 1/4 with the funky oblong hole. If I found VD rotors that are not drilled (no squarish hole), I could do that myself and just not have floating rotors. Will look into TDI.
    update, as my friend corrected me on the pegasus thought, they do have them and also have the TDI stuff, not sure how I missed that.........working on a solution.
    Does anyone have photos of their Reynard FF showing the starter and bracket set up as well as options of exhaust systems?
    Australia
    Default Reynard discs
    Hi there, I run an 84 Reynard in Aust and having issues finding front discs. Who is TDI please?
    Cheers, Scott
    Liked: 706
    Quote Originally Posted by Scott Blake View Post
    Cheers, Scott
    Two Dogg Inc: https://www.twodogg.com/
    Kelowna B.C.
    Default Reynard 82f
    I am in the same boat looking for front and rear rotors
