Results 1 to 13 of 13
    Orlando, Florida
    Default Driver shoulder cover
    What is the part called that is snapped into the cockpit around the drivers head and shoulders after they are strapped into the car? I’m sure it is aero of some sort as well as safety element but have never seen them available. Are these parts custom made for each chassis or are they available for sale somewhere? Any help and info is appreciated…. Thanks group!
    Senior Member mmi16's Avatar
    Liked: 307
    Quote Originally Posted by Steve Stone View Post
    I have only seen them used in professional series - F1, IndyCar, F2 etc.
    Sacramento, California
    A head surround?
  4. The following 3 users liked this post:
    Liked: 1262
    Quote Originally Posted by Lastminuteracin View Post
    A head surround?
    Yes - Many FC drivers have them.
    Liked: 802
    If the driver sits low enough in the car such that the surround is at his ear level, it’s a safety device; if his entire helmet is above it, it’s merely cockpit aerodynamics…..
    Liked: 4349
    Yeah, head surround ....nudge, nudge .... wink, wink ......
    Pittsboro IN
    Liked: 281
    They are chassis specific and if it is properly designed and you sit low enough then it is a safety device. If you do not sit low enough or it is a poor design they can do more harm than good
    Liked: 1262
    They can severely impede your exit ! I had to help a kid out of his in tech once.
    The latching mechanism was 'janky' and he couldn't get it unlatched.
    Liked: 3291
    In my Citation F2000, I sit so low that the FIA padding on the cockpit side structure functions as a head surround with only an inch or so between my helmet and the padding.
  11. The following 3 users liked this post:
    Liked: 802
    most drivers I know intend to just "burst" through it when exiting in an emergency; can't see wasting time fiddling with tiny fasteners
  14. #11
    Orlando Florida 32812
    Liked: 605
    They're called a bolster among other terms.....made from padding - which can be custom molded - which is what I'll guess you're seeing.. You (sitting in the car with a helmet on and buddies to help make measures and cuttings) can make one - using padding like stuff available at Pegasus racing. It may end up being a not as pretty as seen on TV three piece piece held together with a bunch of duct tape and/or zip ties....but it may help save your neck
  15. #12
    Santa Clarita, California
    My Pro Mazda has one. They are sold by the supplier of the Pro Mazda parts in Arizona.
    Fortunately I’m able to get in and out of the car without removing it, I just have to remove the steering wheel.
  16. #13
    Liked: 1262
    Primus sells them for the Van Diemens
    https://www.primusracingparts.com/Pr...ent_p_297.html
    They do make things look "finished."
