    Wheaton, Illinois
    Default SVRA also allowing porting
    Earlier this year a friend told me about the new SCCA rule allowing PFMs to modify their Renesis motors by porting. I was curious if this would also be allowed in SVRA, so I asked, and the answer is yes.
    Here is the quote from SVRA:
    I have reviewed the SCCA Regulations pertinent to the Formula Atlantic class and the classification for the Renesis rotary engine. Based on our rules recognizing "1980 - current" open wheel racing cars, it is appropriate to allow the street or bridge-port modification as outlined in the Formula Atlantic Rules.”
    I hope this helps.
    I don’t think I’ll do this to mine, at least now now, I thought some of you might find this helpful.
    Arlington, Texas
    I bet it makes more power. That has to be a good thing!
    Senior Member tige00's Avatar
    arizona
    The Renesas is junk to port been done as it does not work with the Renesis exhaust ports, need to change to original 13b rotor housing for porting just ask mazdatrix it doesn't work.
