Gemini #08 built in 1982 as a rocker arm suspension car front and rear. The car was converted to outboard suspension at some point.
Complete car that runs, stops. Shifts as it should
Did some laps at Nelson ledges a couple weeks ago and the worked well. Only issue was a miss coming out of the carousel which I attribute to the carb. I did remove and clean the carb but did not change jets or check float height prior to the test day.
Car comes with 3 spare set of wheels. spare suspension pieces, spare bodywork and some new r35 practice tires.
Also included in the sale is chassis #05. Has chassis plate. The chassis does have some damage due to water freezing in the frame. Repairable imo.
Chassis 08 has logbook and a good fire bottle. Will need belts. I inspected and flushed the fuel cell and believe it to be usable. Glad to answer any questions and send more pictures if interested.
Asking 8.5 k
Don
