Results 1 to 8 of 8
    Muleshoe, Texas USA
    Liked: 160
    Default Aim ECU config files
    As I am updating some of my data systems I decided to check for current ECU config files from the Aim website. At one point I believe there was an ECU config file for the old original ECU and a new one for the new style ECU. I see neither listed on Aim ECU lists.
    Anyone point me to them?
    Jay
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
    Liked: 285
    I don't believe there is a Honda FF document, but there are several ECU protocols available with RS3 ECU selection. In the Manufacturer list under Honda, I see FIT_FF and FIT FF21S. I think those are the two protocols you are looking for.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Muleshoe, Texas USA
    Liked: 160
    Default Rs2
    David,
    I should have said I am looking in RS2 as I run Evo4 with G Dashes in all my cars. I am not familiar with RS3 but will look around in it and see if I can find what you are referring to.
    Thank you,
    Jay
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
    Liked: 285
    Won't help. RS3 is only for Aim Products newer than the EVO4 (ie, the EVO4S).
    On RS2, I only see the Honda / FIT_FF protocol. Note this is variant of the Bosch MS4.3 used in Grand Am, so you can also use Bosch / MS43_GA and deselect channels that don't provide useful info.
    David Ferguson
    805-238-1699
    Muleshoe, Texas USA
    Liked: 160
    Default Honda Fit ECU
    OK, I see the Honda Fit_FF in my RS2 - I just was not seeing it under any of the ECU lists on the AIM site and that led to my questions.
    I just received the new ECU file from HPD - it is: HONDA_FF F21s_@20190321_103729_007052.xc1
    Do you know how to get it into RS2 or is it only a RS3 file type?
    Thank you for your help.
    JM
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
    Londonderry, New Hampshire
    Liked: 101
    Quote Originally Posted by Messenger Racing View Post
    JM
    xc1 files are RS3 only.
    NY
    Liked: 127
    Jay, I run an older AIM MXL Pista data system with the original HPD ECU.
    In Race Studio 2, when you go into Device configuration, my selection shows the following:
    ECU Manufacturer: Honda, ECU Model: FIT_FF
    Will Velkoff
    Van Diemen RF00 / Honda FF
    Muleshoe, Texas USA
    Liked: 160
    Default Rs2
    Will,
    Thanks - yes I see that on my system just could not find any reference to it or updates on the Aim website. And I have learned that the new ECU file only runs in RS3 generation dashes.
    I run 2 EVO4 with G Dash and I have just acquired a third VD FF with the MXL2 but won't take delivery for a couple more weeks.
    Thanks and good luck with your races!
    JM
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
