    Pittsfield, Mass.
    Default Shock identification
    I am servicing the shocks on my car, and not able to
    cross reference any in web search. I believe they are
    Bilstein, although searches on their site come up empty,
    These are gas pressure mono tube.
    Appear to be Bilstein but ??
    s/n 36047180113 360/100
    These are from the rear, and the numbers
    are same side to side.
    Anyone have any idea as to their Manufacturer??
    recognize the numbering scheme??
    Best.,
    Guil
    Liked: 1880
    Try posting a picture - it works wonders in identifying things.
    Winter Garden, Florida
    Liked: 160
    Bilstein. The 360/100 represents the rebound/compression fixed valving
    These numbers are an abbreviation representing 1/10 of the Newtons for that shock. For example, a valve rating of 275/78 means 2750 Newtons rebound and 780 Newtons compression. Higher numbers have firmer damping forces than lower numbers, thus a shock rated at 255/70 will be stiffer than one rated at 175/60.
    Sydney, Australia
    Liked: 146
    Quote Originally Posted by pooch776 View Post
    And if my memory is correct - sometimes it has let me down - those forces are at the metric equivilant of 20 inches per second. Which is not a shock speed you will normally encounter in these type of cars.
    Liked: 160
    [QUOTE=Hawke;638741]And if my memory is correct - sometimes it has let me down - those forces are at the metric equivilant of 20 inches per second. Which is not a shock speed you will normally encounter in these type of cars.[/QUOTE
    Close.... .52 Meters/Sec.
    Pittsfield, Mass.
    Default pictures
ID:	102588   Click image for larger version.
ID:	102589   Click image for larger version.
    CA
    Liked: 246
    Quote Originally Posted by gtwiss View Post
    Definitely Bilstien as mentioned above. PSI at Sonoma raceway can rebuild. Todd
