Has anyone else experienced a failure of the end ribs inside the Van Diemen / Elan USF2000 rear wings?
See attached photos. Both ends are cracking around the nut inserts.
This was a new rear wing purchased in 2020, not used until 2021. About 5 race weekends, no impacts.
Edit - to clarify, the issue is on the lower element where the end plates attach. The rib and the wrapped wing material are sanded flush. Although in the photos it looks like the rib is recessed slightly from the wing surface, it is not.
