Results 1 to 8 of 8
    Los Angeles
    Liked: 21
    For Sale 2013 Tatuus PY012 CN2 Chassis #008
    I bought this car in 2016 while working in Germany with the goal of running Europe’s iconic tracks in a fully capable downforce car, and found the Py012’s technical specs and build quality to be exceptional. I tested with the car at Mugello and Spa before importing it to the ‘States in 2019, and I’ve since run a limited testing schedule at Buttonwillow. Work commitments preclude a more ambitious racing schedule, but the car is NASA and SCCA P1 eligible with technical and spares support available from Tatuus.
    Some technical details of the PY012s:
    • FIA specification carbon fiber monocoque, crushbox, and extraction seat
    • Torsion bars on all corners
    • 3rd spring ride height control front and rear
    • Shim-adjustable pushrods which mount directly on billet uprights for reduced stress on the control arms and variable load transfer options.
    • Adjustable droop limiting
    • Brembo monoblock brake calipers with differential bores, dog engagement hats, and low friction front-pivot master cylinders.
    • Drysump oil reservoir which mounts directly to the front of the engine via machined interface and nests neatly into the monocoque.
    • Inboard longitudinal Sadev SLR82-14 6 speed sequential transaxle
    • Sadev hydraulic paddle shift includes shift without lift and downshift blips
    • Magneti Marelli ECU and comprehensive data system including brake pressures, fuel consumption, suspension and steering movements, multiple wheel speed inputs, etc.
    • Oram SP-2 double adjustable dampers
    • Quick release steering hub with integral electronic connection
    • OZ 1 piece magnesium wheels
    • Integral push/pull wheel safety pins
    • Excellent quality throughout
    • Highly detailed factory technical manual and spares catalog
    • Tall drivers fit comfortably
    Specifics of chassis #008 include:
    VdeV race winner, 2014 Portuguese Champion, original French and Portuguese technical passports. Currently located in Buttonwillow, CA in excellent condition.
    • Honda K20 CN specification 2 liter engine with 620 miles/997 km from fresh at 8200rpm map setting (8700rpm also available via rotary switch on steering wheel). In CN guise these motors typically produce ~265hp with a duty cycle quoted at 5500-6000kms by Autotecnica at 8200rpm.
    • Paddle shift system with 499 miles/803 km from full Sadev refurbishment
    • Tatuus updated air to oil cooler
    • New NAS aircraft hardware on complete suspension
    • Optimized front suspension rollcenter
    • Fresh O’Leary rear dampers
    • Updated 45mm OD primary stainless exhaust
    • Circuit racing rear diffuser variant
    • Currently unwrapped in “no secrets” carbon and E glass_ready for your graphics
    • Custom carbon fiber headrest with additional shoulder clearance
    • Electronics cool airbox
    • Updated engine intake snorkel
    • Heat shielding and attention to detail throughout.
    Spares
    The spares for the car are extensive and total over $46K in value. Highlights include:
    • 3.5 additional OZ magnesium wheel sets (4.5 wheels sets total including those on the car)
    • Sticker mounted Pirelli rains
    • FIA carbon nosebox
    • Front splitter
    • Complete rear wing and alternate flaps
    • High downforce arched diffuser
    • Suspension control arms_new
    • Torsion bar and antiroll bar selection
    • Complete range of all set up shims
    • 20 Sadev gear ratios
    • New halfshaft/CV assembly
    • New Brembo rotors_full car set, plus additional rotor and hat assemblies
    • Engine ancillaries: Starter, alternator, sensors, ignition coil sets, coolers
    • Complete 48mm primary OD stainless exhaust system
    • Sachs clutch
    • Specialty hardware
    • Motorola radio
    Please email for extensive itemized spares inventory spreadsheet
    Price
    ***SOLD***
    Contact
    Michael Scully: slingshot44@gmail.com
    Roseville, CA
    Liked: 46
    Default Top Notch
    Anything of Scully's is guaranteed to be top notch. His stuff is always beautiful.
    Los Angeles
    Liked: 21
    Quote Originally Posted by John View Post
    Thank you, John!
    M
    locust valley, ny USA
    Liked: 142
    very cool car!
    Destin FL
    Liked: 647
    Stunning
    V/r
    Los Angeles
    Liked: 21
    Here are a few more pics-
    First some liveried body-on shots which capture the car's 2014 championship-winning season in Portugal (prior owner) and help describe the exterior shape a bit better than its current unwrapped motif:
    And my own two favorite dare to take me flat Euro corner sequences:
    Cheers,
    M
  7. The following 7 users liked this post:
    Orlando, Florida
    Default PY012 Beauty
    Thia is a wonderful Prototype car, owning her is very rewarding as she preformes as well as she looks! Thank you Micheal.
    MVS
    Orlando, Florida
    Stunning
    Thank you Rick, she is a dream to drive and own!
