Results 1 to 12 of 12
    Senior Member schiconst's Avatar
    Daytona Beach, FL
    Liked: 26
    Default FF Simulator Info
    Does anyone know of a simulator program that has FF's on it? I race does not. Thanks,John
    Merry Christmas to all!!
    South Carolina
    Liked: 676
    Quote Originally Posted by schiconst View Post
    Original rFactor had an [unofficial] Lola CF. I may still have a copy of the file if you choose to go that route
    Swift DB-1
    Kingston, Ontario, Canada
    There’s a Russell Alexis Mk 14 for Assetto Corsa:
    https://www.racedepartment.com/downl...s-mk-14.24419/
  7. #4
    Liked: 4356
    This is certainly not my area of expertise, but I was under the impression that Formula F/F1600 racers were using the Skippy cars in iRacing. Similar lap times, speed, and handling.
  9. #5
    Contributing Member cjsmith's Avatar
    Columbia SC
    Liked: 95
    I drive an FF and use I racing. The closest thing I have found and use is the USF2000 car. Using this car I run lap times about 6 seconds a lap faster than I do with my FF on the same track. I like practicing on a car that is faster than I can go in my car, (with in reason). It improves your timing and car control and reaction time. You have to tune the chassis and wings to work for you. For me, this had the closest car feel and tire grip to what I experiance on the track.
  10. The following 4 users liked this post:
  11. #6
    Buffalo, New York
    Liked: 269
    The Gen 3 Spec Racer on iRacing runs times similar to FF
    You can use 2-5 for a closer gear ratio as well, only downside is it is a paddle shifter.
    Are any OW cars on iRacing not paddle shifters?
  13. #7
    Daytona Beach, FL
    Liked: 26
    Default Sim
    Thanks to you all!! Great info. John Schimenti
  14. #8
    Senior Member bhayes's Avatar
    Pendleton, IN
    Liked: 65
    ProjectCars has an FF. I think they call it Formula Junior or something like that. It is a fairly modern Kent powered FF car.
    In iRacing, I have used the Skip Barber car for similar lap times to FF.
    ___________________
    BradHayesRacing.com
  15. #9
    Lynchburg, VA
    Back before I went to college there was a simulator called netkar-Pro that I raced in a league. They had european FF1600s and FF1800s.
    Assetto Corsa was developed by the same company. Haven't played Assetto Corsa yet though.
    Andrew Spencer
    1990 Red Devil F500
  17. #10
    Sonoma, CA
    Liked: 37
    Default Alternative
    For iracing I detuned a Lotus 49 F1 car. I started by limiting the throttle to about 60 % and shifted way below the normal rpm. I turned the limited slip all the way down and then shortened the gear ratios until they matched my vintage Titan gear usage.
    It did take messing with suspension settings, sometimes by trial and error but I could drive it around Sonoma Raceway and Laguna using the same gears and throttle applications within 1 to 2 seconds of what the FFs run. Did take a lot of messing around. If someone is interested I can supply the settings I use.
    The key was the latest updates to the tire dynamics model.
  19. #11
    Member Jake King's Avatar
    New Jersey
    Liked: 33
    Default Some modern FFs for Assetto Corsa
    Here's a link: https://perendinator.blogspot.com/se...pen%20Wheelers
    You can find a Mygale w/ a Honda motor and a modern Van Diemen w/ a Ford motor by scrolling down. Both treaded and slick tire models. They're a bit twitchy. I've found that softening the rear a bit and making some other suspension tweaks will help counteract the snap oversteer.
    This page has some really decent mods. Make sure you download his drivers and extensions so the physics are all up to date.
  21. #12
    Liked: 227
    Quote Originally Posted by BorkRacing View Post
    You can change the iRacing set up from paddle to sequential. I have used the sequential on USF2000, Pro Mazda, Skippy and SRF.
