Results 1 to 6 of 6
    third stone from the sun
    Liked: 101
    Default swift 016 suspension problem
    Hi All, Just completed a suspension overhaul and setup the car to the factory baseline numbers , took the car out on a test day and noticed that at slow speed approx 5 mph the car pulls to the left. brakes are not dragging and wheels are free wheeling any ideas?
    Dee
    Liked: 285
    Caster, Camber, Toe, Tire Pressure or Corner weight is probably not equal side-to-side.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Liked: 101
    thanks dave will check them
    Dee
    Liked: 803
    If car was indeed set to factory specs, could it have been as simple as a crown in the road/paddock wherever this occurred?
    Liked: 101
    Ian, this is your old car #23 I drove it over different surfaces with the same response
    Dee
    Stillwell, Kansas
    Liked: 32
    Default Front WB Bracket
    The front lower wishbone, forward pickup is not located in the center of the tub. All Swift 016s are this way.
    The front lower wishbones must be set to unequal lengths to be square to the tub.
    Mirl
