Results 1 to 6 of 6
    Senior Member tige00's Avatar
    arizona
    Liked: 49
    Default F5000 spring rates
    What spring rates do people run on their f5000 cars, specifically the rear.
    miami
    Quote Originally Posted by tige00 View Post
    Rather broad question....mucho variables.
    Auckland New Zealand
    Default F5000 spring Rates
    Talon MR1a, I typically run 400lb/inch. Have run as low as 350 and as high as 500
    the car has rear motion ration of about 2
    arizona
    Liked: 49
    Thanks for your reply
    Liked: 1401
    You need to know what the motion ratio of you suspension system. Next you need to know how much weight a corner is supporting. I start with a spring rate that gives a wheel rate equal to the weight that corner is supporting.
    Example, you have a corner that weighs 400 pounds. You could have a motion ratio that is say 2 to 1, one inch of shock movement to 2 inches of wheel movement. The un-sprung weight on the corner is 75 pounds the weight of the wheels, tires uprights, etc. The sprung load would be 325 pounds. For a spring rate of 350 at the wheel you would need a spring of 1400 pounds per inch on the shock. Numbers like this example are for cars running with very low ride heights. If you want to run a 3" ride height, vs a 1.5 ride height, you can a lot lower spring rate. maybe close to half.
    The best ride height is determined by analyzing suspension geometry. I pay a lot of attention to the location of the roll centers and pick ride heights based on the roll center locations.
    arizona
    Liked: 49
    Great info thanks so much
