Results 1 to 10 of 10
    Contributing Member steve everard's Avatar
    Nashville TN
    Default Wing slot effect
    Rear wing formula continental
    made up of 3 wings, the gap between top wing and middle wing is 5mm on one of my wings and on my backup wing it is wider gap at 15mm, what effect does this have? More or less downforce, drag etc
    thanks
    steve
    Los Angeles, CA
    Liked: 290
    Google 'Rear wing slot design pdf' and you will find more than you want to know.
    Liked: 350
    Quote Originally Posted by steve everard View Post
    thanks
    steve
    Short version: It all depends. Wing shape. Angle of attack (including relative to each other.) Speed. There's probably more, but I never achieved my boyhood dream of becoming an aeronautical engineer so not an expert.
    Peter Olivola
    (polivola@gmail.com)
    Liked: 3292
    thanks
    steve
    A wider gap reduces drag with a somewhat smaller reduction in downforce. My current rear wing has a 15 mm gap.
    Contributing Member lmpdesigner's Avatar
    USA
    Liked: 35
    Default WIng slot gap
    When I was with Audi and their LMP program my middle finger was "calibrated" as the optimum slot gap for their rear wing. My finger became the official "go/no go" gauge for the team!! (LoL)
    PS: My finger measures 16mm.
    Contributing Member phantomjock's Avatar
    Red Neck Riveria, FWB, FL
    Liked: 105
    A lot depends on what you are trying to do.
    Is a lot like an airfoil with leading edge slats and flaps. When are these used? Low speed, high AOA landing.
    Now turn it "upside down" for downforce. Tailoring that slot is going to depend on where you want that maximum effectiveness. At one particular turn - or at a few? The speed regime at that point on a circuit; the HP available for he remainder of the track; advantage for grip at a critical point, many factors. It goes on, and on, and on, and on.
    A lot of possibilities - and fun to explore the varied options. Sorry I don't have a quantifiable answer. Like before:
    "..it Depends"
    Balance the downforce. If the nose lifts - yer-done.
    Cheers - Jim
    BTW - that is why active-aero is such a great idea! We could "trick" slats could do their job at high AOA - and gain advantage in a fight - all in fun.
    Destin FL
    Liked: 645
    Mine is 15mm as well.
    V/r
    Iverson
    Senior Member GAC's Avatar
    Peoria, IL
    Liked: 91
    The effect of the gap varies with the design. On a 1997-1999 Dallara Indycar, widening the gap increases downforce and drag, which was not what we were expecting at the time. So you have to test it to know for sure.
    St Charles, Mo
    Liked: 159
    Default slot gap
    Quote Originally Posted by GAC View Post
    I spent some time testing various wing - flap assemblies in a small wind tunnel and in cfd using full car drawings. It turns out that not only is the gap important, but so in the fore - aft location......and that is specific to the main plane upper profile.
    The Van Dieman upper pair is pretty good as it is normally found....about 12 to 15 mm gap.....at any reasonable angle of attack.
    The VD lower element needs a small wicker (.25 inch) to be very effective.
    Remember the angle of attack is relative to the air flow direction as it comes off the car. That is usually downward at some angle.
    Therefore an angle of attack that works best on one brand of car will usually be different on some other car. Frankly, at the lower formula, most of the manufacture will not know (they sometimes don't even know what spring rates to run) so do your own testing.
    Every wing profile will generate downforce at some angle of attack. The trick is to get the best downforce vs drag ratio.
    There is a thing called the "drag bucket".....a range of angle of attack where the downforce can be adjusted without changing the drag significantly. Beyond that bucket, the drag goes up very quickly. In general lower angle of attack is better.
    When you reach the drag bucket upper point, a slotted flap (or at least small wicker) is better than more angle of attack,.
    However, the flap chord should be no more that 50% of the main plane chord. That brings up a front wing flap discussion which I will save for a later time. I will just say this: very large outboard flaps are only ok if directly in front of the tire (same for dive planes on the end plate). To do that would require a very narrow track, or a wing to wide to comply with the rules.
    Jerry Hodges
    JDR Race Cars
    Destin FL
    Liked: 645
    Jerry, good stuff here.
    Quote Originally Posted by JerryH View Post
    Jerry Hodges
    JDR Race Cars
    V/r
    Iverson
