Results 1 to 5 of 5
    Santa Clarita, California
    Default Premix amount per gallon
    So what’s the consensus of how much oil to mix with the race gas? Starracecars recommends between 1 and 2 ounces per gallon. What is everyone doing?
    Also, what brand of 2 stroke oil? Synthetic or Castrol or ????
    I did 1oz/gallon of Sunoco 98GTX. I used Idemitsu pre-mix developed in Japan specifically for the motor.
    I don't suspect anyone did enough testing to know if there's any difference on engine wear between 1 or 2oz. RPMs you choose to sustain and shift at will have the most effect on wear.
    Senior Member tige00's Avatar
    arizona
    Liked: 49
    My brother and I used to run a periphal port, idemetsu is the best, and 1 ounce per gallon as 2 it starts to lean out your mixture
    arizona
    Liked: 49
    My brother and I used to run a port, idemetsu is the best, and 1 ounce per gallon as 2 it starts to lean out your mixture and we were at 11,000 rpm, I know your not near there so 1 ounce is perfect for you
    Round Rock, Texas
    I usually do about 1.5 haven't really been picky on what 2t oil I use, I think most racers go closer to 1 as less oil prob means slightly more combustion and power but it will also wear the engine faster.
