Thread: Axles
    Wetmore, CO
    Liked: 110
    Default Axles
    Just wondering what the length of axles people are running with an FC to FB conversion. Specifically Novak if possible. I have 18.75 but I think they are too short for 20mm CV (tripod) joints... And still too short for 26mm CV joints... but its what the car came with...
    PM, email, or txt
    Cj
    920-904-6099
    Liked: 707
    I don't recall Dan having any problem with the axles when he ran the car. Have you had a problem when you've been on track?
    Wetmore, CO
    Liked: 110
    Default CV's
    Well, I blew out a cv last year with no indication why... Replaced it and ran fine.... for the rest of the season.
    Over the winter I replaced the tripods, housings, and axles with identical parts used prior as a proactive measure for reliability. The plungers were siezed in the hubs and not moving so I fixed that as well.......but assumed the parts previously installed were still ok for measurement/size/etc. (my fault) Then blew a CV out 5 laps into the season again this year causing the diff to shift in the car destroying the carrier bearings. Over the winter I replaced all the rod ends which were bottomed out previously which pushed the suspension out in the rear another 1/4" which didnt help.
    Now all is replaced with the recommended snubbers on the axles, etc between Primus, Young, and Taylor....... Upon mockup it shows only 3/4 of the tripod engaged at the diff. So either I need a longer axle or a wider CV. Still trying multiple configurations with all the parts I have accumulated over time to find the best solution.
    cj
    Santa Rosa, CA
    Liked: 268
    Default axles
    You could always install a spacer to move the joint out which would be far cheaper than new axles.
