Thread: Voltage issue
    Classifieds Super License Skelly's Avatar
    Clovis, California
    Liked: 81
    Default Voltage issue
    Hello all
    Need some help on an issue. Our Honda engine is putting out 14volts at the alternator, but while reading the computer with the car running the ECU is only reading 11.4 volts and the car has a bad miss off of idle. This is on a spectrum car.
    Sean
    Liked: 4359
    I am not familiar with that issue. I would first check that the ballast resister wiring is not broken. That is two of the small wires on the master switch. Not the two for the injector circuit. One of those wires goes to a ballast resistor and then to ground and effects the transition between battery and alternator voltage .... if I recall correctly.
    We once had the thick cable from the alternator to the starter be wonky. No stumbling, but it would not charge.
    Clovis, California
    Liked: 81
    Thank you Greg. I will check that out.
    Sean
    Toronto
    Liked: 15
    Default check ECU
    I had a new (1st gen) ECU that had an issue with the firmware where it was reading the voltage lower than actual. If you have access to a known good ECU try swapping to confirm your voltage readings.
