Where do I pick up the RPM signal on a 494? I am using the blue 50volt RPM (blue) wire on the MyChron 3 Plus Gold.
Thanks for any and all help.
i Used to pick it up off the red wire from the Stater tri-plug that went to the CDI box.I think (/6) in the software to get the correct RPM. If you use a 18 gauge wire, you can stick into the plug as you put it togather. Then secure the plug
Thanks Lance. That worked.
Dave
