SOLD
Pictured:
- 7800 series double adjustable dampers from KAZ (75mm displacement variant)
- 4x damper rebuild kits
- 4x Digressive Pistons (never installed)
- Comprehensive valving/shim kits (no shims used)
- 8x spare Aurora spherical bearings for 7800 DA damper eyes (circlips included)
- 4x Upgraded hollow steel damper shafts (never installed) for 75mm variants
Associated manual/drawings/CAD models for reference: https://www.kaztechnologies.com/downloads/7800-piggyback-double-adjustable-shock/
Pricing:
- 4x 7800 DA Dampers (75mm), rebuild kits (the o-rings/seals), and spherical bearing set - $1100
- Valving/Shim Kits (everything in yellow boxes) - $800
- Set of 4 unused digressive pistons - $450
- Set of 4 Hollow Steel Upgraded Damper Shafts - $150
SOLD
