    Junior Member Brian Searles's Avatar
    Perth, Australia
    Default Toyota 4AGE bellhousing bolt pattern
    I'm looking for the bell housing bolt pattern for a Toyota 4AGE engine.
    I'm making an adaptor plate to a Hewland Mk 9 gearbox.
    Any help would be appreciated.
    Senior Member Raleigh's Avatar
    Sydney, Australia
    Quote Originally Posted by Brian Searles View Post
    Should be easy to pick up a front wheel drive 4age box and use the bell housing for your template. I have given them away in the past only requiring the engines.
    https://www.gumtree.com.au/s-ad/dian...box/1254023208
    http://www.ae86drivingclub.com.au/
    https://www.rollaclub.com/board/?ct=1598865597
    Liked: 433
    I have a 4AGE in my Lotus 7. I also have a spare gearbox with bell housing. If you have no other sources I can make a paper template and mail it to you if need be. IM if you like.
    Graham
    Fallen Friend
    Pensacola, Florida
    Liked: 168
    Default Don't mess up crank center
    Transferring bolt pattern as above is fine, however most important to get centerline of crank right...same for alignment sleeves/pins.
    Don't assume.....think/plan it out, confirm, before cutting metal.
    Bob L.
