Curious where you PFM folks are mounting your transponders ?
Thanks in advance.
Geoff
Thanks in advance.
Geoff
The pro location was on the rear wing stay.
I put mine in the sidepod on the left beside the battery.
Haven't tested it yet but it should work as it's just a bit of fiberglass there.
Oh confirmed mounted on tub pointed down inside the side pad beside the battery zero issue with transponder pick up. Worked great.
