My buddy Chuck has a Webster gearbox on his Formula Ford. It shifts easily into 1,2,3, and 4 as well as it goes easily into reverse. All shifts with minimal, even pressure as it should when rocking the car. Once in reverse, it is stuck and stuck solid. Rocked the car, rocked the car very, very hard and still stuck. Removed the rear cover and wedged the reverse selector out with a screw driver. It took way too much effort. Also removed the side detent spring and sprayed with penetrating oil hoping that the ball was sticking. Anytime the gearbox is shifted into reverse, it sticks. We have not driven this car and the previous owner was not much of a mechanic judging by the numerous other issues that we have corrected on this car. Any suggestions would be welcome. Is the idler gear in backwards, shift rod bent, shaft detent burred, shift fork hanging on something, shaft out of adjustment, detent ball burred, detent hole boogered, etc. Please help.
