Results 1 to 5 of 5
    Senior Member KVS84's Avatar
    MA
    Default BMW S1000RR Haltech Platinum ECU w/ Wiring Harness
    BMW S1000RR Haltech Platinum ECU w/ Wiring Harness. We have run this set up for 5 seasons on our Stohr WF1. This will work with any 2010-2014 BMW S1000RR Engine. Entire package to run a BMW in your car!
    - Platinum Sport 1000 ECU loaded with 110 octane map
    - HP4 Igniter Module
    - Dual Wideband 02 Sensor Controller
    - Wiring Harness
    - BMW Throttle Bodies converted to mechanical throttle with fuel injectors
    $2500
    *SOLD*
    -Keegan
    P1 #84
    Stohr WF1 BMW
    MA
    https://www.apexspeed.com/forums/sho...in-Stohr-F1000
    If you purchase this kit you could have a very easy BMW install !!
    Only reason for selling is we are upgrading ECU's to run the newer 16-17 BMW engine. The BMW has been discussed a lot over the years. A stock BMW makes the same horsepower as a fully built Suzuki without the reliability issues. Want to know what it's like to have 35 psi oil pressure idling hot? Shifting at 14-14.2K RPM's is a real treat, these engines sound fantastic.
    -Keegan
    P1 #84
    Stohr WF1 BMW
    Vancouver, BC, Canada
    Liked: 232
    Out of curiosity, what ECU is required to run a 16+ S1000RR motor?
    -Mark
    Mark Uhlmann
    Vancouver, Canada
    '12 Stohr WF1
    MA
    We're upgrading to a newer model Haltech to run drive by wire throttle and different Camshaft Sensor.
    -Keegan
    P1 #84
    Stohr WF1 BMW
    MA
    Default Sold
    SOLD - Thank you Apexspeed!
    -Keegan
    P1 #84
    Stohr WF1 BMW
