    Santa Rosa, CA
    Liked: 268
    Default hydraulic clutch piston
    Any chance anyone happens to have an annular clutch piston for a March 87B, looks to be the same as the 87C Indy car or maybe other March cars. Attached is a drawing of the part
    Detroit area
    Liked: 23
    Default hyd clutch- believe it or not
    i think i might hace one or a couple - can you send me a photo of the drawing so I can read the dimensions pete@tir.com
    Jerry Got Lucky- I had what he needed!!
    Liked: 157
    Default Dale Carter?
    If no used parts, consider asking Dale for a quote to make you a new one
    Santa Rosa, CA
    Liked: 268
    Default clutch piston
    Thanks for your suggestion however I was lucky in that a fellow racer saw my request and actually had the parts I needed. As I found out this part was common in the mid 80's for March but now no one seems to have any. Same for the throwout bearing but thanks to the same guy I also have a good one to use. Who would have thought........
