Page 5 of 5 FirstFirst 12345
Results 161 to 198 of 198
  1. #161
    Albany, NY
    Liked: 238
    Quote Originally Posted by Chris Livengood View Post
    Google the Lock Picking Lawyer. It will turn you off on locks. The old saying that they keep honest people honest certainly rings true. Most locks are such garbage that they only really deter crimes of opportunity. Anybody even remotely determined can easily get through that vast majority of locks.
    Agreed. But the one I quoted requires the best lock picker to open it.
  2. #162
    Liked: 948
    Default It's not just the locks.....
    It's also the latches. My featherlite trailer has a pair of aluminum flat bar latches that are easy enough to cut through and open without bolt cutters.
    So I drilled 5/16" holes through both the side rails of the door and opening frame. Then slipped the quick release pin through. My pins are 3-1/2" long. I have to climb over the car to install or remove the pins, but the door can't be opened even if the locks are cut.
    https://www.aircraftspruce.com/catal...clickkey=21748
    https://www.fastenal.com/products/details/3123077
  4. #163
    Vancouver BC
    Liked: 471
    That's a little bit similar to my trailer.
    The rear door is "locked" from the inside with a couple of 4" long 1/4" bolts that just drop through tabs on the door and into the frame of the trailer. You have to clamber over the car to unlock the rear door.
  5. #164
    Albany, NY
    Liked: 238
    Quote Originally Posted by alangbaker View Post
    What is the security for the side door?
  6. #165
    Lafayette INdiana
    Liked: 295
    mine is a travel trailer latch....not very secure.
  7. #166
    Vancouver BC
    Liked: 471
    There is no side door... ...but there is a front door closed with a laughable little built-in deadbolt.
    Only it's a very small door.
  8. #167
    Liked: 948
    Mine as well, but it does have a deadbolt with a steel strikeplate bolted behind the door frame. Someone would have to destroy the door, or use an electric shear to cut the aluminum wall panels....
  9. #168
    Lafayette INdiana
    Liked: 295
    I suppose mine does too. Thanks for that positive info!
  10. #169
    Lafayette INdiana
    Liked: 295
    Default brake pads
    On Sunday i started hearing a squeak which sounded like a pad down to the metal, to my ear. If that is what I have will I find metal in the dust inside the wheel?
  11. #170
    SoCal
    No matter what the noise is, it’s worth removing the wheels and taking a look.
    If you use Hawk Blacks I have LD19 and LD20 pads available cheap.
  13. #171
    Lafayette INdiana
    Liked: 295
    Quote Originally Posted by ewcmr2 View Post
    I pulled the rf and examined. The rotor is a bit thin but pads are pretty good. There is more wear on the outside of the rotor. I am running whatever came on the car so I don't know what they are. I can look at the bill of sale. I suspect I have 20s front and rear. They are willwood practically brand new.
  14. #172
    SoCal
    Order rotors now! Primus and a Pegasus had none in stock. It took weeks for me to get front rotors.
    (how thin? Front ld20 rotors start out at .375”, rear ld19 at .250”)
  16. #173
    Lafayette INdiana
    Liked: 295
    I'll have to measure. One side of the rotor is worn more than the other.
  17. #174
    Lafayette INdiana
    Liked: 295
    The new pads and rotors came today after ordering yesterday!
    They look correct as well.
    Wooo hoo!
  19. #175
    Lafayette INdiana
    Liked: 295
    I attempted to install the new rotors but the six securing screws heads are too big to get out. l Does the hub need to come out to get them in?
  20. #176
    SoCal
    Snug them back into place, then remove one at a time in the caliper void/space.
  21. #177
    Lafayette INdiana
    Liked: 295
    Ahah! I put the caliper on too soon!
    Thanks very much!
    Tom
  22. #178
    Lafayette INdiana
    Liked: 295
    Unfortunately the void under the caliper is the same as all the others. Still no go. It looks like I Have to get down in the hub and remove the four nuts and pull the hub to get at it.
  23. #179
    SoCal
    Bummer, must be a 99+ change.
  24. #180
    Santa Cruz, ca
    Liked: 183
    sounds more like the stock uprights. Big fat & heavy. The newer billet upright made by Fast Forward and sold by Primus have plenty of room to install the rotor bolts.
  25. #181
    SoCal
    My ‘94 has original uprights, with plenty of room at the front and back to remove rotor bolts.
  26. #182
    Lafayette INdiana
    Liked: 295
    My car seems to have some 97,98 and 99 parts. I believe it was originally a (continental?) with front and rear wings.
  27. #183
    Lafayette INdiana
    Liked: 295
    My ‘94 has original uprights, with plenty of room at the front and back to remove rotor bolts ????*??
    Maybe the rotors are attached with incorrect bolts with larger diameter heads....?
  28. #184
    Lafayette INdiana
    Liked: 295
    <br>
    <br>Maybe the rotors are attached with incorrect bolts with larger diameter heads....?
  29. #185
    Lafayette INdiana
    Liked: 295
    I got the right bolts today.....also learned about the block that had to be removed to get all the stuff in through the caliper space. Looks like maybe it is a one inch spacer?
  30. #186
    Lafayette INdiana
    Liked: 295
    So the new bolts seem fine and I go to install the new rotor and find the bolt circle is a quarter inch different so I won't be able to run tomorrow...drat!
  31. #187
    Lafayette INdiana
    Liked: 295
    So now it seems there are no right side rotors available and all other style rotors are not in stock at present. Apparently the rotors are directional. I am wondering with the lower speeds at autocross running two left side rotors will matter?
  32. #188
    Ontario Canada
    Liked: 160
    I am the one that has these rotors made, and they are not directional for operation only looks. They originally when we started to produce them, came only in one direction. Unfortunately at we are facing machine time and raw material delays in our current production. Hopefully that will be rectified soon.
  34. #189
    Lafayette INdiana
    Liked: 295
    Thanks David! I have now ordered the right rotors.
    Tom
  35. #190
    Lafayette INdiana
    Liked: 295
    I struggled yesterday getting hub back on on the left front. Just finished it. Today am planning to install the new primus rotors. These little bolts to hold it on look really tiny. They are right? I took them off the car so they should work.
  36. #191
    SoCal
    Probably right, 5/16” wrench for jet nut? That’s what mine has, all the load is in sheer in the larger section of bolt.
  37. #192
    Lafayette INdiana
    Liked: 295
    That sounds correct.
    Thanks very much!
    Tom
  38. #193
    Lafayette INdiana
    Liked: 295
    I got all the new rotors, pads and such installed on the front, then decided I should change the pads on back. Ordered them, got them and installed them this morning. All seems fine. The rotors spin freely and are loose enough to rattle a bit. I plan to race at Grissom on Sunday.
    Thnaks for all the positive help!
    I'm heading out to get a new infrared temp guage.
    Tom
  39. #194
    Lafayette INdiana
    Liked: 295
    Raced at ft. Wayne on Sunday. I bedded the pads a bit in the paddock area. They all worked perfectly Got three dnf and then rained out..
  40. #195
    Muleshoe, Texas USA
    Liked: 160
    Default VD
    Glad you finally got some seat time - that is the best cure for all projects!
    Jay
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
  41. #196
    Lafayette INdiana
    Liked: 295
    Quote Originally Posted by Messenger Racing View Post
    Jay
    The brakes work grandly but I still got a small squeek in one of my braking zones.
    Am planning to run this weekend. Also have a co driver for Nationals now, so I need to get registered for that.
  43. #197
    Lafayette INdiana
    Liked: 295
    Default at nationals now.
    Got in all the runs we wanted yesterday. Ben Menendez came by and chatted a bit. He noticed I am not running a sway bar on the rear right away.
    Reid found it would push a bit . We reduced air pressure until it became neutral. We will run the test and tune and the class today to get the drivers more seat time. It was a lovely morning and evening. After lunch it got very hot. we spotted some coolant on the ground at one point and looked all over for a leak, finally deciding it must have been somebody else.
    The car was flawless. I added something over a gallon of fuel at the end of the day. The efficiency of the Honda is impressive.
  44. #198
    Lafayette INdiana
    Liked: 295
    Default New wheels
    Just thought I would update my activity. I sold the Van Dieman to Texas and now have a Honda s2000. I like it so far and am getting some new shocks and perhaps tires for it. I have very much enjoyed my time here at Apexspeed. It is a cozy community with a lot of very experienced people.
    I miss the Van Dieman but with the s2k I can haul a grandchild.
    See you on the track!
    Tom
