Results 1 to 10 of 10
    third stone from the sun
    Liked: 101
    Default Source for caliber O rings
    Looking for O rings to fit an ATE caliber on a Ralt Rt5 1982 , the pucks are 1.65 in /41.9mm in Da. any idea on a source.Thanks,Dee
    Liked: 1879
    Maybe check with Dave Bean?
    Powhatan, VA
    Liked: 143
    Call Keith Averill
    Florida Keys
    Default ATE Rebuuild Kit
    The last few ATE rebuild kits I bought (from some west coast buggy shop) were so old the o-rings had turned to dust. I finally gave up and started using square section metric o-rings from McMaster Carr. Check their website, for your dimensions. Only available in Buna-N so not optimal for long life, not a problem if you rebuild seasonally.
    Liked: 1879
    maybe just search for them on the 'net. look at suppliers like Zatkoff.
    Sacramento, California
    Liked: 23
    Default ATE caliper kits
    Quote Originally Posted by Dee View Post
    Can you post the piston diameters? When I rebuilt my SV calipers, I was able to source new parts from a Porsche aftermarket supplier.
    Liked: 101
    Default Thanks, for the help
    Thanks all, was able to get some from back east and a couple of kits from the UK
    Denver, CO
    Liked: 24
    Default source
    I found EPDM o-rings to fit ATE's at www.theoringstore.com. ordered AS568A 223 for nominal 1.625 id x .125cs. they are round, which their website said can be used in place of square, and they fit/working great.
    by the way, what brake pads are you using in these calipers?
    SeUSA
    @Fleetdude, Round section orings/seals for a brake caliper is not a good idea, they will "seal" but they will not provide the "return" that a square/rectangular seal would, and, the sealing area is much smaller.
    Liked: 23
    Quote Originally Posted by jkrt125 View Post
    That is correct. Provide them with the piston diameter and groove width:
    PMB PERFORMANCE
    162 W 9240 S
    SANDY, UT 84070 855 786-7104
    Contact This Porsche/ATE supplier for correct seals:
