Thread: Clutch issue
    Mokena IL.
    Liked: 59
    Default Clutch issue
    I have a new to me 1978 Argo JM2 Super Vee that I'm preparing to race soon.
    The original factory paper work that went to the owner states the car has a .70 clutch master cylinder.
    This car now has a .75 clutch master cylinder and a .75 clutch slave cylinder.
    The problem I'm having is the clutch peddle is extremely firm with a short throw.
    I'm told by the previous owner its a VW clutch and pressure plate with about 10 races on it.
    Is this normal ? Any suggestion to soften the peddle ?
    Thanks Tom
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default clutch issue
    Normal slave cylinder size was 7/8".
    Longer pedal, less effort.
    Keith
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    colorado
    Liked: 162
    It's the ratio of the cylinder piston areas. You're at 1;1 now.
    The .875 slave will reduce force by ~26%
    Going to a .625 master will reduce force by ~30%
    Doing both reduces force by ~49%
    ...all with correspondingly longer travel, more progressive feel.
    Mokena IL.
    Liked: 59
    Thanks Keith and Bob,
    I'll make the changes to the master and slave cylinders.
