I am doing my first work on a swing axle transmission on my new Vee. I needed to replace the gaskets on the axle tube retainer. My question is: how far should the end of the axle go into the side gear? I know about stacking the gaskets to get clearance, but even with more gaskets that came off, the axle is butted up against the inside of the side gear which is limiting the range of motion of the axle by a lot. If I pull the axle out of the side gear by about 1/8" it has full range of motion-but that is a lot of gaskets. I must be doing something wrong.
Garry
