Results 1 to 10 of 10
    Ofallon, MO
    Default Lola T204 Tie rod ends
    I need to replace my Lola T204's tie rod end. Got a set I thought would work from Moss Motors but they are about 1/4 inch too long (the threaded, tapered part that goes into the upright). Specs on the parts available from Moss are not available so I'm struggling to find the right part. Anyone happen to know what car (Spitfire, MGB, etc.), they came from? With that info, I should be able to find the right part. Thanks.
    Liked: 270
    Default Tie Rod Ends
    From memory I thought the 204 had 4" PCD wheel bolt pattern which would imply a Ford product. Dont remember Lola going the British Leyland route like most of the UK guys.
    Could be wrong - often happens
    Phil
    Ofallon, MO
    Default Thanks
    Quote Originally Posted by Phil Creighton View Post
    Phil
    Some say its spitfire, but spitfire doesn't work, so you may well be right. I've got a call in to an outfit in England, perhaps they'll know. Thanks for the input.
    Liked: 433
    Possibly Triumph TR6. All their steering components were slightly different to the Spitfire/Herald parts. See if you can get the dimensions off of those. Rockauto has all those bits too. Just a thought.
    Graham
    colorado
    Liked: 162
    Haven't had to replace mine (T-200) but you might be able to match dimensions at this site:
    https://www.moog-suspension-parts.co...e_rod_ends.asp
    Scroll down (way down) to the bottom for info on the taper dimension. Please let us know what you ultimately find for a solution.
  9. #6
    Member Banger Rally Man's Avatar
    St Austell, Cornwall, England
    Lola t340 ends are both the long RH of a pair from an Austin A40 Farina if that’s any use.
  11. #7
    Also suggest you send picture to this guy, he bought all spares stock when they shut Longbridge down.
    longbridgeltd@btinternet.com
  13. #8
    colorado
    Liked: 162
    Here. From the Lola Factory Parts List for the T202:
    TRACK ROD JOINT: Quinton Hazell P/N QR1072
    https://www.ebay.ca/itm/SET-of-Quint...RWu1pK&vxp=mtr
    Apparently used on:
    1959-1971 Austin Mini (850 Mini) (Cooper) (Cooper 5)
    1970-1973 Ford Pinto
    1968-1971 Austin America
    1959-1967 Morris Minor
    1962-1967 MG 1100
  15. #9
    Destin FL
    Liked: 645
    Quote Originally Posted by bob darcey View Post
    Apparently used on:
    1962-1967 MG 1100
    Nicely done, Roberto.
  17. #10
    Ofallon, MO
    Default Thanks
    Thanks for that info. That may just do the trick. Appreciate it very much.
    Mike W.
