Results 1 to 6 of 6
    cambridge, massachusetts
    Default Battery cut off switch
    Which one to use? Switch with or without alternator protection ?
    Will
    For my motorcycle (Suzuki) powered car I used a simple, big cut off switch (just two big terminals) that disconnects the battery's ground cable from the chassis. I liked the one linked below because it's quick and easy to push and kill. It is mounted on the main roll hoop (right side).
    In front I have a simple, HD toggle that kills the 12v positive lead to most everything (ignition switch, etc.). It is on the left side of the dash with a red cover to increase the chances a corner worker can get to it, too.
    https://www.summitracing.com/parts/l...SABEgIKkfD_BwE
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default Master switch
    If your engine has a magneto or runs an alternator, you need the switch with those extra connections.
    Keith
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    It's a MC engine with a generator. So a two post switch as suggested would be ok?
    will
    Torrington CT
    Liked: 481
    Russ,
    Thanks - now every web site I look at tries to sell me a cut off switch
    Chris
    But this looks like a nice switch...
    Russ,
    Sorry. I know what you mean. I generally spend a short time deciding what to get, buy it, then see ads for it for the next few months. I'll probably be seeing cut off switch ads for a while now, too.
