Due to the extended life we are getting out of the Formula Ford engines now, we are seeing clutch spline problems quite often. When the splines wear out in the discs, and the input shaft spins inside it, the input shaft is almost always ruined. (currently around $650) In addition to ruining your race weekend, this extra cost makes replacing the clutch before it fails a good thing. You can keep an eye on the issue by checking the radial play in the layshaft. (the lower large nut when you change gears) I can't give a number of degrees of play before the clutch needs replacing. When it starts to feel sloppy to me I replace it. I only have cars with F-3 style clutches, so I do not know if the stock clutches also have this problem. I am sure much of the wear is caused by the fact that most of the adaptor plates are not truly square, and do not place the centerline of the engine perfectly on the centerline of the transmission. YMMV
