    Senior Member Clyde's Avatar
    New York
    Default NOS Engine Stuff
    NOS Engine mag case $520.00
    used crankshaft timing gear $ 15.00
    NOS Flywheel $120.00
    NOS Crankshaft $160.00
    NOS Camshaft Engle 120 $ 40.00
    seated only camshafts with lifters (Steve Long PKR + 2engle 120 +130 +scat 45 $ 80,00
    NOS oil pan extension 1 1/2 gts $ 50.00
    NOS Oil pan extension 3 1/2 gts $110.00
    NOS Timing Gear set $ 55.00
    Chrome distributor hold down clamp $ 2.00
    NOS push rods need sizing per engine with ends $ 30.00
    Waterproof distributor cover $ 7.00
    Alum Oil pump cover $ 7.00
    oil filter housing $ 7.00
    chrome coil cover $ 3.00
    Flywheel Gland nut $ 5.00
    Contact Via PM or ajp241 at yahoo.com: shipping extra or pick up in Hagerstown,MD or SUmmit Point Park, WV
    Plainfield, IL
    Liked: 190
    Clyde,
    This could be a great item to sell, but you've left out a ton of info (some of it mandatory)
    First the required = What is the asking price?
    Without that, the ad will be removed.
    What case number? AS 21, AS 41
    Where was it made? Germany (really valuable), Brazil, Mexico?
    Photos are really helpful.
    Bill Bonow
    New York
    Quote Originally Posted by Bill Bonow View Post
    Clyde,
    Bill sorry about the post, I could not figure out how to post pictures of the "Stuff" so I trird to delete the post, I see it did not work. Hopefully I will be able to re-post with info, prices and pictures by Tuesday night.
    Plainfield, IL
    Liked: 190
    Clyde,
    No worries on the pics. Edit them in later.
    You will need to put price(s), that's the rules.
    Bill Bonow
    New York
    Default Nos FV Stuff
    Btt
    Michigan
    Liked: 18
    Default Vee parts
    PM sent. will purchase pump cover and filter housing.
    Frank
    Illinois
    PM sent on Engine case
