Thread: Pre mix??
    Pittsburgh, Pennsylvania
    Default Pre mix??
    Questions ... Do you PFM guys premix? If so what ratio and what injectors do you use? I currently own the standard formula mazda prototype with the series II renesis 6 port. The oil system was deleted and I am wondering if different injectors should be used with the premix.
    Pittsboro IN
    Liked: 282
    Yes PFM's require pre-mix. I don't remember the ratio off the top of my head. It's approximately 5oz/gallon.
    Call Drummond Engines and ask.
    It’s 1-2 oz per gallon. Not more. I premix in the jug before fueling the car. I also got in the habit of putting the oil in the gas as soon as I filled a jug so I never had a doubt whether I had done it or not.
    Ok thank you ...
    Do you all pre-mix?
    HOW about the injectors? I have the green and brown ones but noticed they also show red and yellow injectors on the star parts site. What is the difference?
    The reason I am asking...I am having a problem , the car is stumbling between 2000-3000 rpm. It works fine if you mash the pedal, but actually stalls if you try to bring it up slowly.
    Pittsboro IN
    Liked: 282
    Call Drummond and talk with him.
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 123
    New to PFM. What oil do folks use for pre-mix?
    Idemitsu
