    colorado
    Liked: 162
    Default Mystery Caliper/Upright
    I need a bit of help identifying this caliper and upright from a '70 Rostron FF that I'm restoring. I'm told that the upright may be Lotus 19 but the caliper mounting holes are 2.125" spacing, which doesn't match the type of calipers I'd expect on a Lotus 19. The caliper (top right) is similar to an LF-14 (shown below for comparison), but also has the 2.125" mounting bolt spacing, a ~1.325 diameter piston and the brake pad is a very strange shape. Otherwise it's pretty similar to the LF-14, so I think it's a Girling. At this point I'm thinking I'll convert to LD-19 but that requires a lot of whittling. Any info or suggestion is appreciated.
    Winter Garden, Florida
    Liked: 159
    Default Lotus 51 Upright
    That is an early Lotus 51 upright (may also fit a Lotus 22 & 31). You have one correct rear Caliper (10SP I think) and one front 14LF Caliper.
    Cheers, Joe
    Liked: 159
    BTW, the rear caliper is a Girling 10/8H (not a 10SP) and used on a Lotus Elan.
    Joe
    colorado
    Liked: 162
    Thanks Joe, that's great information. Lee Chapman's site shows the same upright is used for Lotus 22/23, early 41's and the 51's. The Girling 10's have 34mm pistons, I'm trying to get to a brake caliper with around 1.6" pistons. LD-19's or SP12's would fit that bill but neither fits up very well with the upright and rotor without a lot of modification. Later Rostons had SP12's on Lotus 61 uprights. Maybe someone would be interested in trading their later 51 or 61 uprights for these? BTW, the Rostron has LF14's on the front.
