Results 1 to 9 of 9
    Dexter, Michigan
    Default Priming oil system in 1600 Kent Formula Ford engine
    Any great ideas about how to prime the oil system after a new engine is installed or after system oil change?
    Bob
    Tacoma, WA
    Liked: 324
    I used to loosen the supply line from the tank at the pump to fill the line before cranking. My local shop showed me a better, easier and cleaner way - used VERY LOW air pressure in the tank vent line and crank the engine. The pressure comes right up in a couple seconds and then can be started.
    of course you must fill the filter before as well
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Milan, MI
    Liked: 313
    Sort of a combination of previous reply:
    I loosen the connection at the pump coming from the tank and blow into the dry sump vent hose until oil leaks out the loosened fitting. Tighten the fitting and crank. As already mentioned, fill the filter first.
    Dexter, Michigan
    Default priming pump
    Thanks for the input, used air pressure to the oil tank and this worked great.
    Bob
    In all my years in FF, I had just cranked till oil pressure popped up, which was maybe 5 seconds?
    Just for my information, what is "low air pressure"? <30psi? <60?
    NW Colorado
    Liked: 30
    Default Something completely different
    How about one of these????
    http://petersonfluidsys.com/filter-S...merRemote.html
    John Mihalich, Jr.
    Lotus 61/FF/28
    RMVR #61
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 611
    Default Priming system
    I think Bob was dealing with a vehicle that had a front mounted oil tank, thus the method he chose was probably the best.
    Otherwise, remove the plugs and crank works.
    Keith
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Tacoma, WA
    Liked: 324
    Low pressure would be like 5psi. I used an air nozzle sealed with my hand around the vent when I did mine last. I suppose you could use more air, but all you are trying to do is help push the oil to the pump.
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Denver
    Liked: 301
    Be VERY careful with air pressure. Saw someone blow up the oil reservoir (after a track-side engine change) trying this. Big ugly (costly) mess!!!! As noted, loosening the fitting at the pump (from the reservoir) to make sure oil is solid in that line prevents an air pocket in that line from thwarting the pump from being able to suck. Slight air pressure in the reservoir will help expedite this, especially for front mounted reservoirs.
