I have moved to an FC car and no longer will be karting. The kart has less than 30 laps since new, testing only, and has the best of everything. The engine was used by Alex Tagliani at the Florida winter tour a few years ago and like the kart is one of the best out there. The engine had the EVO update, new harness to 2016 spec and updated ignition box. Piston too has only an hour on it. It does not have the 2018 barrel but can be added if need be and sealed for an extra $500 Canadian including new ring if barrel is replaced. A DD2 is the Rotax 2 speed set up. Kart will be supplied with New seat to fit you or the Tillet that is on it barely used, 2 sets of 125mm front and 210mm rear rims for slicks, factory magnesium Birel and one set of of 120 front and 180 rear aluminum for rains. Will come with new 2015 Birel Art decal kit and not personal decals now on kart. Will consider trading for early 90's complete running FC or FF car in okay and better condition, I would expect to have to do some work to car. For pictures text only 306-59-7038.
Asking $ 6000 Cnd
