Results 1 to 12 of 12
    Member RMVR53's Avatar
    Denver CO area
    Default Help to identify uprights - please
    Got a pair of rear upright I need to identify with the help of the forum. Cast in on the lower rear is "BA 42265" . Anybody recognize these and what they are off of?
    thank
    Bill F
ID:	76600   Click image for larger version.
    Danbury, CT.
    Liked: 1906
    6 lug?
    Impressive!
    I have no clue but would assume that they are for a high horsepower application.
    Tacoma, WA
    Liked: 323
    Looks a little like Forsgrini.. Greg Lovell (apex name "Rv Greg") owns a vintage FB in the Seattle area and may be able to confirm if they are. If so, he could be interested in them!
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Tacoma, WA
    Liked: 323
    oops, duplicate post..
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Senior Member rv greg's Avatar
    Puyallup,Wa.
    Liked: 9
    Default Mystery uprights.
    Not Forsgrini. May be Lotus 20 or 23 aftermarket ?
    Tacoma, WA
    Liked: 323
    The 'triangular' shape reminded me of yours, but now I see the short upper section and the disc outboard of the upright.
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Senior Member David Clubine's Avatar
    Ontario Canada
    Liked: 160
    With the 6 bolts and the location of the bosses that could mount a trailing arm I would guess Lotus 18, 19, 20. Definitely wouldn't be Lotus manufacture, they would have been an aftermarket part. Interesting pieces.
    NW Colorado
    Liked: 30
    Default Not Lotus
    On Lotus applications, the universal yoke slips on the axle and on the inboard side. This application, the yoke is forged into the axle Imp style). The hub slips on and the locknut is outboard.
    For the 18 parts see:
    http://leechapmanracing.com/lotus18.htm
    For the 20/22/23 see:
    http://leechapmanracing.com/lotus22_23.htm
    For the 51/61 see:
    http://www.leechapmanracing.com/lotus51-61.htm
    Might be using a Lotus rotor and adapter. What is the Bolt center diameter on the six studs? What is the stud diameter? What is the thread; Lotus used BSF???
    John Mihalich, Jr.
    Denver CO area
    Thanks all for the comments to date. John, I haven't measured it, but I was told the hub is possibly Lotus or at least drilled for Lotus 6 lug wheels. These are the uprights I sent photos to you a couple of years ago. It was J.A.'s T47 project. I hadn't really chased what they were much as I had been told the suspension on the car (a BSR-spec'd 72 Europa) was all Lola 540. Well, recently I had a friend (thanks Lothar) send me pics of his 540 rears and they are obviously not even close. So I started looking through Lotus "stuff" and the closest I have found to date is 18 rears but the key difference is these are up/down vertical and the 18's have about a 6-8 degree "kink" in the middle...like most uprights.
    Front uprights are Spitfire so I'm beginning to think the 540 direction isn't right either unless someone did 540 A arms but Spit uprights. I'll have to un-box the arms and post pics of them as well. Whats the chance these are some kind of production car upright?
    thanks all
    Bill F
    Puyallup,Wa.
    Liked: 9
    [QUOTE=rv greg;554762]Not Forsgrini. May be Lotus 20 or 23 aftermarket ?[/QLotus 19
    Connecticut
    Top upright in photo is Lotus 18 Fjr with drum brake cylinder ears front and rear on casting.
    Second two photos are modified Lotus 18 F-1 or Lotus19 rear uprights with ears for calipers on casting.
    Earlier photo with flat backed upright might be early LeGrand with hub and stub adapted for Lotus 6 bolt wheel. Proper Lotus parts though would have a stub axel with splines on inner for female UJ yoke, not yoke with stub axel and removable hub as in picture. Parts like that were to the best of my knowledge used by Lotus on the Europa and then only with 4 stud wheels. Hope that helps. J.R.
    Denver CO area
    thanks J.R. - I'll chase LeGrand info
    Bill
